Adjustment?
My Bose L1 Model 2, Tonematch, B2 is incredible. Not a regret in the world. Owner for a little about 3 years now, and have purchased 2 more! One small issue I’m had from the start is that my Bose, more than our others, doesn’t stand straight. The top speaker section leans forward. By the time it measures at the top, it’s a good inch off plum. Doesn’t appear professional and weak-noodle looking. I’ve had to place shims between the sections to make it stand straight. Is there anything I could adjust safely to correct this as shims are very tacky.
Thanks-
Alex
fretbuzzrocks.com
aloya,
Thank you for your advocacy and use of our L1 products!
Your array should certainly not be leaning forward to that degree. Other than using a shim (which I agree is tacky) I don’t have a recommendation that could be implemented in the field.
From your website I see that you do reside in the US. Please call us so we can set up service. Also, please mention that you were directed call from the L1 Forum. We will get you straightened out quickly.
