Ain’t Misbehavin’ is a 2 piece band.
Usually just two of us but we add more front line occasionally (Brass)
Playing Swing, Jazz, Latin, Blues , Light rock
Performing in Jazz Clubs, Hotels, Restaurants, Castles, Private residencies, Marquees , Cruise boats Outside events for audiences of 50 to 500
Show type: Quiet background music , Swing music for dancing, Cabaret , Jazz club , outside festivals
Using the L1® System since September 2008
Geographic location: Cheltenham, Gloucestershire. UK
Notes about Ain’t Misbehavin’
Two musicians sounding like more ! We are multi-instrumentalists playing the following : Tenor Saxophone, Baritone Sax, Clarinet, Flute, trombone ,Trumpet Keyboards, male and female vocals. We play in a wide variety of styles~ a very eclectic mix of music. We have over 200 numbers on our play list from which we select ‘on the fly’ to to suit the audience we are playing for.
Bose L1® equipment
L1 single bass and L1 compact (recently added)
Comments about the L1® System
Have been using L1 single bass system since 2008. We put everything through it~ Keyboards/Drums and bass and three mics. It worked fine for us providing there was enough space to accommodate the base ‘footprint’ and get far enough away from it. (sometimes we work in very small venues and its pretty intense close up) We encountered a height problem with the L1 - low ceiling on a paddlewheeler boat so we had to use the bottom half of the column only. We recently added the L1 compact to our array which is much better for smaller venues on its own and is not so tall ! For larger venues and outside events we use both the L1 and the L1 compact, set up to provide an amazing stereo. Overall we are very very impressed with the system,and so are our audiences.
Web Site: Ain’t Misbehavin’ website
The Players
Tony Sheppard: Keyboards, Trombone, Trumpet and vocals.
Diane Atkinson : Tenor Sax Baritone Sax Clarinet , Flute and vocals.
HI Ain’t Misbehaving!
As a result of seeing you (and hearing the Bose sound from the other side of the field) as well as inside the tent at Highnam Court, I have bought a L1 system and will be gigging with it next week for the first time. Wish me luck! time. Peter (Amazing Matchless Band)
Chalk one up for Tony!
quote:Originally posted by Cripps6479:
HI Ain't Misbehaving!
I should be earning sales commission ! Two more band I know have bought L1 sstems after hearing us perform .
you certainly should!
