Controls for aux channel 4&5`
I’m using the Tone Match to hookup a conference call group for our church. I’m feeding the aux output channel 4&5 into a Samsung 4 smartphone that they have conference call software on. The audio signal is great for voice but the people on the call say the piano is garbled: almost as if the tone match is overwhelming the phone’s ability to handle the input. Hookup is via a trrs cable. Is there any way to adjust the aux signal other than output strength?
Hi avguy,
This sounds like the signal for the piano is too hot as you suggested, and/or the phone input is designed for a stereo source. The T1® Aux output is Mono, balanced. I would try using a Tip-Sleeve connection from the T1® to the phone. I’d also adjust the level of the Piano output to Aux. See more information at the bottom of this post.
Originally posted by MattP-at-Bose:
Hello avguy,
The only way to adjust the output level of the AUX send is to adjust how much of each channel you are sending to that AUX send. In this case I would try sending less of your piano channel as it may be clipping the input for the phone. The only other thing I may advise is to be sure you’re sending this source to the AUX output pre-fader so that your volume knob adjustments on the Tonematch do not affect the volume being sent to the AUX output.
If you need further explanation or would like us to assist over the phone please feel free to call the number below,
Thank you,
Thanks for getting back to me. Are there any written instructions available on how to do this? I can’t find anything about it in the manual that came with our system so I will be calling next week.
We have an article here:
THANK YOU!! I’ll try to set these this weekend and will call if I run into problems.
