DJ Purpose
I want to use my Crown CL1 power amp to power 4- b1’s through the mono sub output jack (frequency of the low pass filter 40Hz to 200 Hz) from my Denon DNX400 DJ mixer.Is that possible?
Hi joyex,
Welcome to the forum!
The B1 is designed specifically for use with the L1 Model I and L1 Model II systems, so we cannot recommend using it with other systems. It is certainly possible to connect a B1 to other systems but since doing so would not be the intended use, it would be done at your own discretion.
Thanks for posting!
Many thanks for your early response.
Please needs a little help here if this kind of settings are possible since it is not mentioned
at users manual.
STEREO FULLRANGE WITH STEREO BASS
CONTROLLER INPUTS
Ch 1/Mono Left from mixer
Ch2 Right from mixer
CONTROLLER DEFAULT OUTPUT ROUTING
Channel 1 Channel 2 Channel 3 Channel 4
Routing 802III spkr 802III spkr 502BP spkr 502BP spkr
Left Right Left Right
(Fullrange) (Fullrange) (Low freq) (Low freq)
Limiter Off Off Off Off
Delay Off Off Off Off
Joyex
Hi Joyex,
Our apologies but this forum is intended specifically for our L1 family of products. For assistance with your 802 speakers, please give us a call at (877) 335-2673.
Thank you for posting.
