High gain on channel 3 of L1 Model 1
Just bought a L1 Model 1 used from someone to use as a back-up in case my Classic crashes. Everything checked out okay except that Channel 3 is very loud even when I set the volume to 2 or 3. All of the other channels are fine. The volume knob rotates from 0-10 so I know that’s good. What causes this? I will probably just not use that channel.
Hi kraftyron,
I’m sorry for the issue. If the same source and cable work better in the other inputs for you, then working around the issue can be fine. I can’t say exactly what caused the volume discrepancy though.
