Hi, I have the bose l2 and I was wondering when I play my backing tracks through it with my ipad should I have the playback on the ipad set to mono or stereo, it is connected into channels 4/5 on my tone master. plus I have 2 base bins if I just use 1 in smaller venues will it reduce the volume of the base
thanks ken
Hi Ken,
Thank you for joining the Community.
iPad Connection
If you are connecting your iPad to T1® Channel 4/5 (both inputs) then you can set your iPad to Stereo. That's probably more convenient if you like to listen to you iPad in Stereo when it is not connected to the T1®.
If you are connecting your iPad to T1® Channel 4 or 5 (one input) then you should set your iPad to Mono.
B1 one or two
A single B1 will not be as loud as two, but in a smaller venue and if you are not pushing the L1® very loud, you may not hear much difference using one B1 or two.
