2nd Planet is a 4 piece band.
Performing in venues for audiences of 200 to 2,000.
Show type: Concerts
Using the L1® Systems since June 2005
Geographic location: Northern California
Description about 2nd Planet:
2nd Planet, is a diverse music experience specializing in the styles of contemporary jazz, rock, r&b and funk. The Northern California based band consist of 4 musicians who will utilize their creative gifts to electrify music listeners with their original brand music as displayed in the band’s first CD release “Beyond the Surface” and their 2010 release titled “The Next Level”.
2nd Planet performs in Northern California’s San Francisco bay area and Sacramento area concert venues and also has co-headlined with internationally recognized artists such as Paul Jackson Jr (American Idol’s & Jay Leno’s Tonight Show Guitarist) and Latin jazz artist Ray Obiedo.
Bose L1® Equipment:
Guitar: One L1 Model 1 with 1 Bass module.
Bass: One L1 Model 1 with 4 Bass modules and 1 Bose PackLite Model A1 Power Amp.
Keyboards: One L1 Model 2 with 1 Bass Module and 1 T1 Tone Match Engine.
Drums: One L1 Model 1 with 4 Bass modules and 1 Bose PackLite Model A1 Power Amp.
Comments about the L1® System:
The very best audio system we have ever experienced for small and mid size venues.
Set up time is a fraction of a traditional audio system that contains backline, monitors, mains and a multi channel mixing console.
In larger venues of audiences of 1,000 or more where more sound re-enforcement is needed, the L1’s will still require far less set up time and sound check time, making everything far less stressful for the musician and sound crew.
Web Site: www.2ndplanet.net
The Band:
Clarence Williams: Guitar
Theodore Valentine: Bass
Ron Menefee: Drums
Marvin Eguia: Keyboards
Be sure to take a listen to our music on iTunes at www.secondplanetband.com
Photo Courtesy: Joseph Ehara
In larger venues of audiences of 1,000 or more.
Do you add more Equipments?Your stage look like you have floor monitors.
Please what you use when play for larger audiences of 1,000 or more.thanks
On this stage photo, there was another band that played after us and they used the stage monitors. Also, the band that played after us was not an L1 band, so they used a traditional setup. In regard to playing in an audeince of 1000 or more, typically I would recommend additional sound re enforcement. The L1 would make setup time a fraction of what it normally would take for a traditional audio system configuarion, because of the L1’s wider disbursement of sound. Therefore as long as the sound crew uses direct boxes for the mains on every L1 and provide some monitor mix for the stage, the L1’s would be a great solution for large stages and large audiences of 1000 or more. The option of adding additional audio of an audience of 1000 or more would still be relative to the type of event and the style of music.
Thanks so muuch.
please tell how many microphones you use for the drums and what brand.Thanks.
