L1 Model 2 Stereo - Some final questions
a. If using T1 for setting up the Stereo, will TRS balanced cable work from Aux to the L1 Model II base stand.
b. I am also considering getting the Vestax Spin DJ. It has RCA outputs, can we get RCA->TS or RCA->TRS to get the stereo setup I am wanting to do.
Thanks much guys… Appreciate it tonnes !
Desi DJ
Hi desiDJ,
Yes,
RCA to ¼ inch jack Tip-Sleeve will work. I’ve never seen an RCA to ¼ inch jack Tip-Ring-Sleeve adapter, but even if you were to use one, because the RCA connection is unbalanced, there would likely be nothing gained as compared to a common RCA to ¼ inch jack Tip-Sleeve converter.
Desi DJ
Thanks much, ST. Appreciate it !
Desi DJ
I actually have a rca to Tip-ring-sleeve in my tool box. I have no idea why I bought it or what I will ever use it for.
