I have a job this weekend where I would like to use my L1s and compact as the “mains” on either side of the stage, but I may have to use a qsc and/or my s1 pro wedge as well (for the drummer and the lead singer). I just got the t8s, but I’m not entirely sure how to connect all this properly. My assumption is to use 1/4in trs cables from the outs on the t8s into the L1s and channel 2 on the compact. Would I run the wedges into the main outs on the t8s?
Hi Charlie,
Thanks for the details in your question.
Charlie posted:
I just got the t8s,
Please make sure your T8S is up to date by following this link.
Yes!
You can use the T8S 1/4 inch (6.3 mm) Tip-Ring-Sleeve main outputs.
You can connect the T8S XLR outputs to the monitors (wedges).
The output of the 1/4 Tip-Ring-Sleeve and XLR jacks are identical. This means you'll get the same signal going to all four loudspeakers (L1S, L1 Compact, monitor(s)).
If you need a separate monitor mix use the Aux outputs for the monitors. For details please see
T8S Aux Outputs
![[local image not available]](//discourse.chathispano.com/uploads/default/original/1X/46eb5d07f755c7df7534e109599ce8d83f21353a.png)
Please click the picture for more details.
