Is there a way to have more than one output from the L1 Model 2/ Tonematch? As I see it, the Tone Match has one output. I use that for the input of my recorder. But there are times I would also need to connect my signal to a church’s system so they can also record and even have it in their PA. So, how do you do that without a Y? I haven’t wanted to use a Y because I’ve understood it to create a small degree of signal loss. I wonder it that’s really the case. Is a Y the only way to do this other than using another mixer of sorts? Have you heard if that really does create a noticeable signal loss?
Thanks…
Hi Kenny Carter,
I have answered your question here: Output Question
Plese note: There’s no need to post things multiple times.
Thanks.
