I am using a ESP-00 II frame's serial output to send commands to a RS-232 controllable FM tuner. I'm planning to send a preset function to change the radio station each day. If I use a terminal program on my PC, I can get the 5 x preset commands to work correctly with the FM Tuner. Once I enter these 5 same commands into the serial out module in ControlSpace, Go On-line and test - nothing happens. Is there anything I need to add to the string for the Bose unit to send it properly? I've tried all sorts of combinations of CR, LF etc ......
The string I am trying to use is:
#|D001|web|SELPR1|4|U|return
This is a Preset recall for an Audac FM/DAB Tuner. I've attached the serial document if you have any ideas??
