I was surprised today to find that the maximum signal delay in a DSP block is only 1 second in the 1RU’s. The ESP00 and PM amps still have 3 seconds.
I had a call from a dealer with an ESP880 who is trying to sync video and needs 'at least 2 seconds’
So it looks like he’s going to make string of signal delay blocks.
Can we make the delay time be the same on both ESP series?
Is there a need or would it be a problem to make the max time longer?
JR
Hi John,
That’s as designed, there are technical reasons why it’s different on the 1U ESPs. So for the very rare applications where >1s is required then you can just chain together multiple blocks.
Best regards
Rob
Hi John,
I prefer 1s delay module more than 3s delay for 1U ESP. We can use over 40x modules of 1s delay in a single ESP. If it were 3s, we could use only 15x modules or below because of the limitation of the memory capacity for the delay. That would cause a shortage in the number of delay modules in some projects, wouldn’t it?
Best regards,
Kakudo
