Sub cone color
Has anyone noticed this color on their sub cones
Hi Jephsound,
That's a call to Bose. They will take care of you.
Call Bose® Product & Technical Support at (877) 335-2673
(U.S. and Canada only)
I'm in Michigan,  only one of my subs has this issue..... I'm also having an issue w/ the F1 tops, upper magnet not holding, when trying to use in reverse J which I don't do all that often.
Hi Jephsound,
I know that Bose will want to work with you on the spots and the magnet issues. Please call them. They are good people.
Hi Jephsound,
this sub is new or used ?
New
may be rubber from 10" cones. it looks like pre-aged. Or residuals from packaging ?
it appears only on the grid ? or the drivers are damaged
It is actually on the cones themselves.  I don't want to take the cage off, I noticed when I sat side by side for for a show we were doing. Definitely a difference between one sub and the other. Still produces sound as to what extent if any, is sound degraded I have yet to check. I plan on giving Bose a call today as suggested earlier.
