If you are using a TC-Helicon Mic Mechanic, check out this new article in the L1® Wiki with tips for using this device with a T1® or Compact.
(thanks to Roy for the heads-up about the firmware update for the Mic Mechanic)
And thank you, ST for continued maintenance of the Wiki! I just got a Mic Mechanic and was wondering about the sibilance issue. I discovered the firmware update, but didn’t think to bypass the mic preset on my T1 (Audix VX 5).
I was surprised at how much I’d had to roll off the high end via EQ, but otherwise liked the unit. Sounds like a definite improvement!
Mary
Hi Mary,
Great to hear from you!
Hope that all is well. Do you ever head north of the border?
Hi there! No, I don’t often travel north. But I think about it!
