Using two L1's
I have a gig coming up and i’m gonna need to rent a second L1. I currently have the classic with tone match. can you tell me how to hook up a second L1 to double the power?
thanks
vegas
Hi Vegas,
If you are adding another L1 Classic or L1 model I, the best way would be to run the master out of the Tonematch into channel 1 or 2, and then use the XLR line out on that channel to daisy-chain the signal to the second system. You will need to keep the trim level on the power stand fairly low, but you should be able to adjust the volume to get a balanced sound.
If you are renting a model II, then you can use the Tonematch cable to connect it to your Tonematch Engine, and then connect the Tonematch to your classic system using a 1/4" cable from the master out.
Let us know if you have any more questions, and thanks for your post!
