I have (2) two Bose S1 Pro’s and (1) Electro-Voice ELX200-12SP 12-in Powered Subwoofer . I wish I had the money for the Bose Sub, but this is the best I can do for now. Anyway, The Sub does NOT have an active pass-through. That is, it does not filter out the lows going to the tops. The input and output are hardwired internally to be in Parallel. That being the case, which setting is the best match for the S1’s?
80Hz
100Hz (Default)
120Hz 150Hz
ELX200-10P
Thank you
WirelessDJ
