Hi,
T4S.
What type of eq does the 3 band eq provide?
And what is the frequency range of each control?
Thanks.
Hi,
T4S.
Thanks.
Hi Kenny,
zEQ automatically adjusts the center frequency and range depending on the ToneMatch preset you currently have selected, so there are no fixed frequency ranges that the zEQ manipulates. For example, the zEQ center frequency and range will be different on a vocal preset compared to a bass preset. For more detailed equalization control, I recommend using the ParaEQ.
Hi Dylan,
What type of eq does it provide? Is it a shelf type? or a wide bell? Narrow bell? Or something different?
Hi Kenny!
The T4S/T8S zEQ low, mid and high are all shelfs - they are variable cut off points which change depending on which ToneMatch setting is selected.
