Bose product name 321 GS Series II
Country USA
2. HDMI to RCA Cable, 1080P 5ft/1.5m HDMI Male to 3-RCA Video Audio AV Cable Connector Adapter Transmitter for TV HDTV DVD
3. GETFIT HDMI To 3 RCA HD Digital Video Audio Converter Adapter
Also...am I understanding it correctly that I must somehow view my BOSE settings on a laptop or device to change my setting on the BOSE to optical? How do I do this exactly?
I'm not seeing my BOSE menu on the new TV, and the tech support from BOSE could not help-she did a BLIND setting trial that failed, so I am not clear how I view this Bose menu to change the settings exactly, what settings do I choose (OPTICAL) and how to access this?
I found this information online for settings, but I need to figure out how to even see this somewhere to get to it...suggestions?
I would really appreciate any clarification on these items and the settings procedure.
THANKS - AMY BRACKEN
POST SEQUENCE I HAVE BEEN FOLLOWING FROM 2020
Hello
I have the above and am trying to connect to a new Samsung Smart TV via the optical cable.
The 321 GS works perfectly but the Optical port has never been used.
When I setup the TV to use optical it sets up seemingly okay but there is no sound on the BOSE.
The optical cable shows a red light at the BOSE end so the optical cable is working.
I have no other optical devices to test the BOSE.
What can be wrong?
The only thing I can see is that the BOSE optical input is not working.
There is nothing in the manual at all about the optical input.
The TV only has one output, the optical.
Bose product name
321 GS Series II DVD Home Entertainment System connecting to a new Samsung Crystal UHD TU7000 75" TV
Country USA
