Adding a Bose Stick sub to my two S1 Pros, with Mic and Guitar
Bose product name
Country
Must be confused to how this site works...  I am trying to add a subwoofer to my configuration of two S1 Pros using a Mic and Guitar as my primary inputs...how do I add the sub?  Off the slave unit?
Hi Needles,
Welcome to the forum! Thanks for stopping by.
I'd recommended lining out from your primary S1 Pro to the secondary S1 Pro, then lining out from the second S1 Pro to the subwoofer.
