Adding TC Helicon Mic Mechanic 2
Hello,
I was thinking of getting the TC Helicon Mic Mechanic 2 to add effects to the vocal since L1 Compact does not have any reverb.  My question is do I feed the signal coming ouf the TC Helicon to the Mic input of L1 Compact or Line input?
If I feed it through Line input, I don't have control of Bass or Treble.
So, should I or can I feed it through Mic input on the L1 Compact?
Also, TC Helicon Mechanic 2 has a Tone button which performs some Eq'euing, can I use that feature or do I have to leave it off if I want to run the signal to Mic input on L1 Compact?
And lastly, has anyone use the TC Helicon Mechanic 2 for vocal with L1 Compact?  Does it sound good?  Any advice or suggestions are appreciated.  Thank you.
Hi Duke,
duke posted:
Hello,
I would try the L1 Compact Channel one.
We have an article about using the
TC-Helicon Mic Mechanic with the L1 Compact
The principles should still apply although I can't tell from the online documentation for the Mic Mechanic 2, if you still have the "Less Bright" option for the Tone feature.
I have used the TC Helicon Mic Mechanic (not the 2). I found it worked fine either way
  • Connected to L1 Compact channel one with the Tone feature off or set to less bright
  • Connected to L1 Compact channel two
    • with the L1 Compact ToneMatch switch set to line level (down)
    • TC Helicon Tone feature on.
ST, you are always so quick in responding and so knowledgeable.
Thank you so much.
I hope to hear more from others as well.
I use with S1 Pro.   But the Tone match on S1 Pro and tone button on Mic Mechanic attempt the same auto adjust in areas such as EQ so I turn off the Tonematch on the Bose as it seems to give the best balance for me.
David
I'm working with a slightly pitch challenged singer right now -- this may be the perfect solution.
Thanks!
David Wyatt posted:
David
Same for me.
