wrote:
Thanks for the detailed response, very helpful.
Glad to help 🙂 I noticed you didn't say if you have a Boselinked or a SoundTouch AV35. Can you let me know which one you have? All you have to do is turn it over and look for the Watts as shown in the link I provided above to figure that out.
Also, you didn't mention the subwoofer your AV18 used, is it an LSPS III as shown in the link I provided earlier?
wrote:
- I have looked at my SA-2, and it turns out to be an SA-3, with an AUX in! Which is great.
- I hooked up my SA-3 to my AV18 successfully.
- I enabled local source auto detect on on the SA-3 and tested that with a bluetooth receiver successfully as well. excited!
That's even better news than you might have thought. You don't even need to use the AV18 to run it. Read the post I made here to help 🙂
wrote:
- I have tested my SA-4 with Soundtouch as an independent system as well.
- Worked good with the iOS app, although the connected was spotty and dropped a few times. Not sure why, not too excited about spotty connectivity over wifi, which is surprising. Maybe I just need a wifi extender outside.
- I tested the soundtouch controller as well. It worked, but was unable to 'wake' the SA-4 from stand-by. Although I could successfully wake it from the iOS app, then the soundtouch controller would reconnect and work somewhat. Not sure if there is a defect there.
- I was surprised by the very limited functionality on the soundtouch controller. Not able to navigate sources beyond presets. But maybe that is to be expected from old tech, not sure.
I try to hardwire all my devices. So if you have the ability to, I would run ethernet to every device you can. Be it your TV, cable box, gaming devices, speakers, etc. You could even use Powerline adapters where ethernet is passed through the home's electricity.
I think the controller you mention is the circular one. It looked interesting when I saw it 5 or so years ago, I think it was designed to be a simple remote with a basic information display on it.
wrote:
- OR if i buy my missing power supply for the bose linked AV35 and go that route. Not sure what i gain, since it sounds like it cannot use the SA-4 as a second zone, and I would need to purchase a wireless link adapter to make it soundtouch compatible (which is discontinued at this point)..
Use the AV35 for a better home theater experience with the ability to play lossless audio. While it doesn't support 4K, you can still use 4K with it as I show in this guide.
wrote:
- OR if i can daisychain the SA-4 to the SA-3 using a boselink cable. Although, I only have a single boselink A, and one boselink B. Not sure if I need a second boselink A cable, or if daisychaining would even work with the SA-4,SA-3 and AV18.
No, the SA-4 cannot work with the SA-3. The SA-3 is Boselink and will work with Boselink, the SA-4 uses a similar shell to the SA-3, but internally it has been redesigned to work with SoundTouch.
Bose should have never use the same plugs for both and they should have removed all mentions of BoseLink on their products, but I can only guess that was a cost-saving measure as they only had to change the internals of their receivers and accessories to create new products with new features and functions.
wrote:Getting there,, just dont want to pick a deadend path with obsolete tech. Sound is not a trend, it is a vital part of life. I am in this for the long run
If you're going for the "long run" then look into wiring as much of your wireless tech as you can to your home's router. Wiring modern tech to your ethernet port should be considered an essential part of modern-day tech.
Also if you are going for the "long run" remember, you are using tech which ranges from 5-15 years old. So you might want to look and see if you can trade-in your tech for something newer. It's listed as "option 2" in this guide. Though I will point out that it might be time for Bose to upgrade that system soon.
