When I use the "Alexa, Turn on TV" command, it works fine. When I use the "Alexa, Turn off TV" command, nothing happens. In order for me to get Alexa to turn off my TV, I have to use the "Alexa, Turn on TV" command again. I know that this is not normal. Not sure what other troubleshooting I can do.
Bose product name: Smart Soundbar 300
Country: USA
Firmware Version: 3.0.11-1134 0a36e05
App Version: 4.3.3
What devices were you using that were affected and what version are they on: Sanyo FW40D36F 40 inch TV
Detailed description of the issue and steps to reproduce: Tell Alexa to turn off TV
What environment do you experience the issue in? Quiet Room
When did you start to experience the issue? Did it work correctly previously?When I got the speaker. Turn off command never worked
Any troubleshooting steps you took: reconnect speaker to Alexa
. This is very strange indeed. Just to confirm, when the TV is on, and you say 'Alexa turn on TV' it turns off? If so, do you have any other Alexa devices in the house and do they behave the same?
