Anyone know panaray lt 4402ii(v2) & lt 9702ii(v2) & 502bex & 402 eq parameter and crossover setting?
Anyone know panaray
502bex & 402
i can't find in website
Bose product name
Country
Hi Joshing,
Crossover is normally determined by the frequency responses of the two speakers in combination. This information should be available on each product's technical data sheet on pro.bose.com (some will be in the discontinued section under 'resources')
However, I would recommend downloading ControlSpace Designer from: Here
We have EQ curves, HPF values and crossovers listed for all of the speakers you mentioned.
This would make it easier to determine where to set these on your DSP or amp.
Thank You,
ChrisJ-at-Bose
