Apagado bateria baja
buenas me paso que se me apago el bose s1 pro por bateria baja puede ocurrir un problema por esto?
Hi Henderson and welcome to the Bose Pro-Portable Community!
I should mention that our Community provides support in English and so I encourage you to reach out through your local support channel(s) if you wish for correspondence in Spanish.
I have however, translated your inquiry and can see it relates to the S1 Pro Battery. The expected Battery Life of the S1 Pro System is up to 11 hours after a full charge (Note: Louder volume levels use battery power more quickly)
We also expect the system to be fully charged within 5 hours (3 hours in Quick Charge)
I hope this helps.
