Apple lossless via qc 25
Do my wired Bose QC 25 support apple lossless?
Bose product name
Bose Quiet Comfort 25
Country
What devices were you using that were affected and what version are they on iPhone 8
Hey , you'll be able to stream Apple lossless audio by using the 3.5mm to lighting adapter. As per Apple's FAQs "The Lightning to 3.5 mm Headphone Jack Adapter is designed to transmit audio from the iPhone’s Lightning connector. It contains a digital-to-analog converter that supports up to 24-bit/48 kHz lossless audio."
You can find Apple FAQs regarding lossless audio HERE.
Let me know if you have any further questions.
Thanks for the anwser, that‘s what I have figured out as well. I suppose they don‘t support high resolution lossless, though, do they?
