Hi, John.
John posted:
Thank you that is generally what I thought would be the case. One last part (b) to the first question. I know the quality will be different using other than Bose but will the tweaking and effects of the T1 tonematch play through the additional non Bose speakers.
I have often used my T1 and L1 Compact and with third-party PA systems. I am super comfortable with the T1 and I have often use the ability to create a separate mix (Aux) to send to the third-party system, but that was because that third-party system was sophisticated enough to have its own effects and EQ. If you want to read more about that see
If the third-party powered loudspeakers don't have effects or sophisticated EQ, you might be fine connecting the L1 Compact Line Out to the powered loudspeakers. Go easy on the reverb. You may want to hear some reverb in the monitors, but it's probably not necessary (and possibly counter-productive) to send reverb into a large room. That's another reason to learn about the Aux output. There's no reverb in the Aux output.
Going back to the simple connection (L1 Compact Line Out to the powered loudspeakers), here is an excerpt from an article
Should you or should you not use a ToneMatch preset when using the T1 ToneMatch Audio Engine with other systems?
ToneMatch® presets optimize the sound of a microphone or instrument when used with an L1 system. So this might lead you to conclude that a ToneMatch preset shouldn't be used with other systems.
But that wouldn't be quite right.
If that other system had a similar "voicing" or tonal response as the L1 then you would expect the ToneMatch® preset to be of value with that other system.
There are potentially a class of systems that fit this description. The L1 system is voiced to make high quality commercial recordings sound the best we know how. Some studio systems are voiced the same way, as they are where those recordings were mixed.
Thus, on some studio systems, you should expect ToneMatch® presets to be of value.
Other systems, including PA speakers and monitor speakers are voiced in an almost random and widely varying way, in our experience. Thus, it's impossible to say whether a ToneMatch® preset will help or hurt.
Source: T1 ToneMatch audio engine without the L1
We so much like the ease of setting adjustments.
I'm glad you are enjoying the T1. I do too.
again thank you for the quick response it has made our day!
Happy to help.
