Batter life is only 3 hours instead of the promissed 11 hours
Bose product name S1 Pro System
Country USA
I just bought the S1 Pro System and had my first DJ gig and the battery was fleshing red within 3 hours. So is the battery draining too fast? I took the battery out put it back again and will try again this weekend but very disappointed so far.
Hello djcxp,
Disclaimer:  I am not a Bose employee, and I do not own an S1 Pro.  I do have lots of other Bose gear.
While the S1 Pro does indicate "up to 11 hours" in the manual, that is an optimum, best-case scenario number.  To me, the key words are "up to", in ideal conditions with quiet background music with a freshly-charged battery.  Actual performance is based on a number of factors, primarily the volume and type of music.  Running full volume, battery life can easily be as short (or possibly shorter than) three hours.  Half volume should last 5-6 hours; less than half volume, even longer.  The type of music being played can be a major influence as well.
Check out this great post from a couple of years ago regarding S1 Pro battery life.
