Battery care : keeping the Bose S1 pro plugged for indoor use or not
Hello
I use my S1 pro indoor mostly. I wonder I should let it plugged or if this could overcharge the battery and damage it.
Otherwise, leaving it plugged in would reduce the number of cycles, thus protecting it.
I could also remove the battery from the speaker.
Thank you.
S1 Pro
Hey pyracine and welcome to Pro-Portable Community
You can run the S1 Pro systems with the batteries removed.  It should be noted that its hard to predict whether this will have any significant effect on the battery life. Also, you can find a lot of information online regarding battery care.
What makes this particular question difficult to answer, is the vast amount of variables that add/subtract from the life expectancy of the battery. This applies to all battery powered products.
Some information to help you with your research, the Bose S1 Pro System has a Lithium-Ion Battery with a capacity of 5500mAh.
