Best / cheapest way of expanding LS38 to other rooms with cube speakers
Bose product name
Bose Lifestyle 38 with LSPS III subwoofer
Country
UK
02.02.00
n/a
n/a
n/a
n/a
n/a
n/a
Hi all - I absolutely love my LS38 and was wondering what the best way would be to extend from the living room it to other rooms in the house (kitchen, dining room etc). I know there are wireless transmitter / receiver and old 'RoomMate' solutions but those look clunky and expensive. There also seems to be an abundance of cube speakers available off eBay so wondering if I could install say 4 of these in a couple rooms and then connect back to the console (ideally without having to run a cable all the way back!).
Any advice would be greatly appreciated!
T
 wrote:
Bose product name Bose Lifestyle 38 with LSPS III subwoofer
Country UK
Firmware Version 02.02.00
Hi all - I absolutely love my LS38 and was wondering what the best way would be to extend from the living room it to other rooms in the house (kitchen, dining room etc). (..) There also seems to be an abundance of cube speakers available off eBay
You would need to use Boselinked amplifiers (either the SA-2 or the SA-3) to power something like the Acoustimass 5. As you noted, older Boselinked devices are only found in places like eBay today. Just know that you will also need to purchase 4 PMC II remotes, one for each room as well.
 wrote:
I know there are wireless transmitter / receiver and old 'RoomMate' solutions but those look clunky and expensive. (..)  so wondering if I could install say 4 of these in a couple rooms and then connect back to the console (ideally without having to run a cable all the way back!).
T
If you're staying with your Boselinked receiver and want sound from it without wires, I am sorry to tell you that a wireless Boselinked transmitter/receiver would be needed. Though there are solutions for the SA-3 to be used independently that might be helpful.
If you want wireless (aka wifi). Since your subwoofer is compatible, so you could always purchase the upgraded AV35 Soundtouch receiver. Not only is it a good receiver, but SoundTouch (which is now discontinued) would be a far better wireless setup than Wireless Boselink.
I hope that this helps answer your question. Let us know what you end up doing 🙂
Remember, all Bose cubes, single or double, need to be connected to a Bose Acoustimass module for the lower frequencies.  You cannot use Bose cubes without the Acoustimass module.  I would check eBay for a couple Bose Acoustimass 5 systems and the wireless linking devices to go with each.
At this point spending any money on your old system would be tricky. Finding the old connecting hardware and speakers a challenge and you would still have an old system.
I suggest you save your money, then sell the old gear and start fresh. The Bose Smart Home line is modern and will do the job quite nicely. Bose Music App and Airplay are great multiroom standards and work very well. A smart sound bar at the centre of your system with the Home 300 speakers around the house and even a Bose Portable speaker would be a great option for outside.
