Best Settings for Voice Matching
I have L1, M2 with T1. I am trying to get the best voice match using karaoke and backing tracks with this. Is the High Volume Music setting the best for my voice matching or should something else be used? I have my EV 767a dialed-in on the T1. I have some delay on the voice now. Using USB from PC to T1. Thanks
Hello Dance Host,
Whenever using the T1 tonematch presets, we always want to make sure that the preset EQ we select makes the audio sound better than it would with just a flat EQ. In this case I’m assuming you’re looking for an EQ for the backing tracks. I would always start with our Tonematch EQ set to flat so that we can hear what the audio sounds like without that EQ set. Then I would try the exact EQ you suggested, High Volume Music, and see if you like the sound better. After comparing the two, you can better make the decision of whether or not the EQ is needed on your background tracks. If you have further questions, please don’t hesitate to call the number below.
Thank you,
