Have a T4s connected to 2 L1 Model II with tone match cables. Is it better to connect the T8S to the L1 analog inputs or channel 5 and 6 of the T4S?
Hello Edmang,
Either way will work fine. There won't be any difference in the quality of the signal. It's just a matter of whether you want to manage two master volume controls.
If you route your T8S into the T4S channels 5 & 6, you have the advantage of controlling your overall volume level from one one place -- the T4S. If you have panned any signals on the T8S, be sure to use the T4S Pan/Aux control to pan channel 5 left and channel 6 right to maintain the panning.
Thanks. Makes sense
