Hi, Maybe you should take a look at this thing. You should get the right sync with the TV although going backwards to a slower Bluetooth you will end up with the same issue
I've been searching for a BT Transmitter with extremely low latency so I can transmit from my Mixer Aux out or Headphone Out to a Bluetooth IEM. This is for singing on karaoke. (I realize this won't work for DJ'ing as even that low latency would be unacceptable).
This seems to be exactly what you're doing. I have also been tracking several Avantree models for the past 4 years. They seem quite costly but I would have to purchase it blindly as there's no way to test it. So have been holding off.
Could you please highlight in detail your experience with the sound quality, the latency (if it's detectable/bearable) plus the quality of Avantree. Any other make/model you can recommend?
Also ... Have you had an opportunity to compare the latency of your Bluetooth transmitter with a product such as the Xvive U3?
