I have Acoustimass 10 series V system ( 2 years back ), I also have Denon 740h receiver.
From day one , i cannot control the sub-woofer level. 12db or -12db has no changes in the effect. The bass is not that good but i didn't compliant because i never got a chance to test it, if i increase the volume then neighbor compliant.
I tried to contact customer support though chat and call. I didn't get proper reply . since warranty is over they ask for service. I am ready to go for a service, but not sure will they do it properly. I read many blogs that service is not proper.
can anyone advice me to resolve this issue ?
if this not possible to resolve then i plan to sell this bose and buy good home theater.
I have tested my receiver with Klipsch home theater. its working as expected. even if i remove the sub-woofer cable from receiver, i still get little bit of woofer sound .
i have two issues 1. cannot control the db using the receiver. 2. even without the wire plugged in. i still get woofer sound. and thats not good.
i had a chat with the bose support team, then guided me to change the cable. Let me reply this thread once i have tested with that.
Well, remember, the Bose Acoustimass module carries the mid-bass frequencies for the cubes as well as the sub-woofer low-base frequencies. The mid-bass is probably what you are hearing with the sub-woofer cable removed. Your receiver probably has a cross-over frequency adjustment if you want to change that.
I don’t think you can control the Acoustimass that way.
Your gain controls are on the side of the module.
Ensure your receiver is set as follows:
Subwoofer ........................................ OFF (not used)
LFE (low frequency effects) .............. ON Crossover frequency ........................ 200Hz
