Hi guys I’ve got bose ds40se speakers and i want it to connect on my pioneer vsx 520 reciever , is it possible? If yes how and would be the wiring install
Hello Genesis,
Sorry for the delay.
Yes you can connect the Bose DS40SE to your amplifier. Although for the best music performance an EQ should be applied (available in our DSPs / amplifiers).
Before you connect the loudspeakers make sure the tab setting is set to 8 ohm:
Next step is to wire the loudspeaker to the 8 ohm terminals:
As the minimum impedance for the VSX 520 is 6 ohm, I would advise to connect one Bose DS40SE per channel.
Now you can connect the loudspeaker cables to you amplifier.
Installation Guide
Advised EQ for the Bose DS40SE:
