Bose ES1 Application Note
Attached you will find the Bose ES1 application note including 2 sample files .
Could you please explain how can we add a second Sennheiser TCC2?
It would be great to have a third sample file according, but also a "to-do" support using the "large sample" as a base to start from would be OK (I am not a Control Space designer expert)
Hello Aleale,
You can add a second TCC2 by dragging in a second TTC2 from the Device View (Dante Endpoints) onto the Project view.
Go to the device view and drag in the second TCC2 from the SP-Tool Kit onto the device view.
Add a second AEC and a HPF and mix (Automixer) the signal of the 2 TCC2s to the Mic Mix (Post-AEC) of the CRR.
As you can imagine every situation is different and therefor we can only create a reference configuration where you can built from.
More information on programming with Bose ControlSpace Designer can be found on our Education Center
Or you can contact you local support team
