Bose esp 880 facrory-reset?
Hello everyone,
I recently bought a Bose esp 880 at an auction, now I am trying to configure the esp 880, first installed the latest CSD from the bose site, then connected the utp cable in my router and run the CSD software, after different attempts and different setting in the hardwaremanger, the ESP 880 is not found, I do not know wich firmware is installed, because it is not connecting, is it possible to reset the ESP?
Thans allready
Martin
Try 192.168.0.160. Depending on your firmware, it may default to that.
Thank you for your response, but still no connection, ip adress is different i quess.
I recently got a serial RS232 card for pc and a null modem cable to try and get the ip adress, is there software i need to install to connect to the esp?
Thanx
No idea, but I would try to connect at 9600,N,8,1 hit Enter and see if it says anything interesting.
I got the ip adress from the esp and changed it, also changed to DHCP, now trying to connect whit controlspace designer, which version do i need to use?
Hello
I see the esp in csd, there is a project installed, now i want to change it, how can i change it?
