Speaker has several pairs of leads. I want to hook up just 8 ohm without power.
Which leads do I use?
Thanks for the correct wiring info.
Tom
Hello English,
you can use 360p as Low Z and bypass the transformer.
To do this - hook the white wire (XFRM) up to your amplifier as signal ( ) and the black wire (COM) as ground (-).
It is recommended to Cap all unused wires.
