wrote:
Hi NeonsNight thanks for the helpful response.
Can I narrow down the potential options by saying that I am after a solution that enables me to get the audio from my Sony KD-65X9500H tv playing through the Bose speakers?
The outputs from the tv are shown below.
We just watch general tv, sports and netflix.(..)
Given the above would you say that the LSPS III subwoofer and an AV35 receiver is the best way to go?
Ah, that's a different question to "i would prefer to not replace the speakers if possible" & what works with your pre-wiring.
The best option is the Lifestyle 650 / 600 / 550 as that has a wireless subwoofer and a receiver that supports 4K, ARC, & CEC. (If you don't know what ARC & CEC means, ARC allows for HDMI to send sound from a TV to a receiver. CEC allows you to send commands like change channel, power, etc via an HDMI cable).
If you go for one of these, you won't use that subwoofer cable (as the new Lifestyle systems have a wireless subwoofer) and the speaker wires would need to be spliced into an adapter that can connect to the receiver. So you need to make sure that the pre-wire location is near where you'd want to put your receiver.
Bose currently sells the Lifestyle 650/600/550 and it is something you should seriously look into. The version that uses the same speakers as yours (though they look different now) is the Lifestyle 600. There have been rumours about Bose coming out with a new one that supports 8K, but it is anyone's guess when that will happen, especially with the global chip shortage.
As this is still a currently manufactured system, it is hard to find without the cube speakers. So you will most likely purchase a full system either new or second hand and have 5 unused cube speakers.
If you go for the AV35 know that it doesn't support 4K, ARC, or CEC. So you will have to wire an Optical out from your TV to the receiver to be able to hear a source on the TV.
I made that guide I linked to earlier that will help you know how to be able to use 4K with an AV35 and it is worth checking out. I recommend Option 3 using a universal remote to ensure you have the best sound.
wrote:
The connector cable that is in the wall is a 9-pin mini din. Photos below of both ends.(..)
And just to clarify, when you say LSPS III subwoofer, the actual models I can buy would include PS18III / PS28III / PS35III / PS38III / PS48III ?
thanks
Yes the LSPS III is the name of a family of subwoofers and it looks like that is what you are pre-wired for.
