Bose model l1- s1 analog input how to connect the mixpult soundcraft ui16
HELLO I NEED ADVICE. I HAVE A BOSE MODEL L1 S1 AND I WANT TO CONNECT THE MIXPULT SOUNDCRAFT UI16 TO ANALOG INPUT. I used 2X MONO JACK and SOUND BEING. HOW TO USE THE CABLE. I DON'T HAVE A BOSE TOUCH T1 THANK YOU LUDEK
Hi Ludek,
Welcome to the Bose forum! Thank you for joining us. I recommend the following setup:
  1. Connect your instruments & audio sources to the Soundcraft UI16 as normal.
  2. As the L1 model 1S only has one 1/4" audio input, connect from one of the UI16's headphone outputs to the L1 model 1S using a 1/4" jack cable.
