Bose Quiet Comforrt 35 II Sweat Issues and best practices if any
Bose product name
Bose Quiet Comfort II Microphone 35 Series 2 (Manufactured on 27 Mar 2020)
Country
India
4.3.6
16.0 Released on 18 May 2021
Samsung Galaxy M 42
I find the sweating under any normal circumstances for even a little longer usage of the phone, even under the normal room temperature. I have also used this outside the house which is alright because at times it is exposed to the different temperature, but again not very sunny. I am surprised as to what is causing the sweating in Bose Headphones which is not the case with the other phones, and what is the best practices if any to avoid or manage the product better - in terms of cleaning advice if any after usage.  I have just been wiping off gently with a dry cloth all these days just to let the sweating evaporate.
I am not sure whether this will make the ear buds catch up with some fungus (over a regular usage), and it may go out of order, and does it get covered under warranty.
Normal room temperature even with the fans turned on, outside the house but not very sunny climate at all.
On every usage for a little longer period of time (say more than 10 minutes or so)
Nothing so far.
Hello Itsraghz! Thank you for reaching out.
Sorry to hear you are having to clean the ear cushions so often. From time to time you will need to clean them to maintain the ear pads. You can remove the ear cushions to check to see if there is residue inside the cushion pads.
You can also order replacement ear cushion kits from your local support team if you prefer a new set.
I hope this helps!
Hi  Thank you for your response. I am just wiping off with a normal /dried cloth gently. Will that suffice, or should I have to make a specific cloth for the better maintenance?
At what period, I can ask for a replacement? As I am under a warranty (extended warranty for 1 more year), I hope I can get a new pair of cushions. But what are the norms? and how many times I can claim if at all? Kindly advise.
Happy to help out!
For cleaning the ear cushions, any cloth will be acceptable as long as it's a soft, dry cloth.
As for replacements, You will need to contact your local support team for further information and they will be happy to discuss all options and details with you.
I hope this helps!
