I have a bose soundbar 700 and bose home speaker 500. I was able to connect my bose 500 to my homekit by searching "add accessories" and use airplay2 but I cant with my bose 700. Tried trouble shooting by reseting the router and the soundbar to no avail.
I have read most of the post relating to this but I cant seem to figure it out.
In addition my bose 700 is connected to my apple tv. I know that you can airplay to the apply tv with the bose 700 playing as its speaker. What I am trying to do is use my bose 700 independently without going through my apple tv.
Hi , I'm not sure if you have solved this issue yet or not but I just found a way to make it work if the soundbar 700 is not showing when "Add accessory" from the Home app.
Here's what I did when it doesn't show up:
Connect the soundbar via AirPlay. For me, I connect it to my phone using Spotify or apple music via AirPlay.
While it is connected via AirPlay, open the Home app and "Add accessory", then choose "I Don't Have a Code or Cannot Scan".
The soundbar will be detected and you can add it.
This works for me, and I hope it works for you too.
