Bose T4S Output Meter
I purchased a Bose T4S mixer and need a bit of assistance. I found an output meter with the rotary knob under "PREFS".  This displays the output level of the master, however without any numbers or colors associated with the meter, I don't know how to read it. I don't know when I've reached clip/distortion levels.
Can anyone give assistance, guidance, or info on the output meter?
Hi DJ8X!
Here's how the level meter looks on the ToneMatch mixers (this appears the same for input and output level):
So long as the peak level indicator isn't hitting the end of the level bar (on the right hand side) then the audio won't be clipping.
For more info on this, see page 17 of the owner's guide.
Thanks for sharing. The output meter works a bit different from the input meter. It does not have a predefined peak level indicator for the output.
