Hi
I have just bought Bose TV speaker from an online store. I was trying to register it on Bose website. However, it showed a product as "Bose Solo Soundbar II". Which was pretty absurd. Both package and Soundbar itself labeled as Bose TV Speaker. I was trying to contact local distributor, but they could not help since it was not procured thru them.
I am wondering if this Bose TV speaker has a variation, for example, different product name in different country/continent? Or this is not a genuine Bose. Photos are attached as a reference.
What should I do in this case?
[Image removed by Moderator]
Hey Jeff G Pin,
What a bizarre experience! Thanks for reaching out.
Where did you purchase your product? And what is your country of residence please?
Have you also ensured the serial number you have entered is correct?
I look forward to hearing from you.
Hi Tegan_M
Thank you for your reply.
I bought this product from an online marketplace so-called “Shopee”. Which is one of the most popular online marketplace in Thailand. A seller is an individual not a store.
Yes, I have tried entering and rechecking the serial number several times. The result was the same.
Thanks again
Thank you for confirming this.
I am led to believe that this item was miss advertised. I have re-entered the serial number you provided into our system and I can confirm that this is stated to be a Solo II Soundbar.
If you require further details about this product, you can find our user guide HERE.
If this is something you would like to complain about, please reach back out to the original seller.
Hi Tegan_M
Thank you for your clarification and advise. I will reach back to seller and return the product.
Thank you very much. I really am appreciated.
