Bose work management application, over VLAN
Hi, One of the partner has two different VLANs setup in their office. One for all AV devices (VB-1 is part of that) and another one is for general purpose use. IT manager wants to check the status of VB_1 from his machine, using Bose WMS. Are there any special settings need to be done to reach out to VB-1, sitting on a separate VLAN?
Navin Datta
Hi Navin,
It should just be like any other IP device. The network VLAN would have to be configured (port forwarding or bridging) to be able to see and communicate between networks. An IT manager should know the proper way to set this up securely. Otherwise, you can connect the VB1 to the larger network to connect to Work Management.
ChrisJ-at-Bose
