Hi, DJ Ron … I didn’t see this note when I was creating my previous post above. Now I understand more of your setup.
Originally posted by DJ Ron:
…At this point the loud hissing sound is coming from the second setup. The one the T-1 is hard wired to is quiet. If I reverse the setup and connect the T-1 to the side that makes the noise and use the other side as the slave, it too makes noise and the hard wired side is quiet.
By ‘hard wired’, I see (now!) from an earlier post that you mean the T1 connection via the “EtherCon” cable … and that you are not using a separate T1 power supply.
It seems to me, then, that the problem is related to an analog output of the T1 and the “other” L1.
I evidently glossed over your setup in a previous post… let me deal with those items …
…The T-1 is powered up last and the volume on the L-1 is placed at 12 O’clock position and the T-1 Volume is placed at 12 o”clock position. I can barely hear any audible hissing sound which is good. I turn up the mixer volume after loading a song with my Denon DN-HS5500 media player /controller and the music plays crystal clear with no distortion at all…
There is no “volume” on the Model II powerstand. That ‘knob’ is the “trim” for the analog input only. If you turn it all the way down, you should either hear no change – or even a slight reduction in the hissing.
Now, regarding the ‘remote’ system:
…Plug the ¼ TRS stereo cable into the L-1 power stand and run the other end to the Master Out of the T-1.
You do realize that you are thus running a
“Dual Mono” setup?
Have you tried a “mono” TS cable … or at least a different brand of TRS (which is actually just being used as a ‘balanced’ mono cable, in this situation)?
By the way, the “Dual Mono” may explain why the bass seems to be ‘out of phase’.
… I match the gain on the power stand to 12 o’clock and the hissing sound is extremely loud. The Left side is a lot louder than the right I turned the gain on the power stand down on the right side to about the third notch to even out the high frequency on each tower.
First of all, it is perfectly normal … expected … that you have the “trim” on the ‘remote’ L1 (Model II) only 1/4 to 1/3 of the way up. I would suggest that you start with the L1 Trim knob all the way down, then – when the volume from the primary L1 is “right”, bring up the Trim gradually on the ‘remote’ L1 until it matches in volume
(you’ll have to walk back and forth between them to really judge this “equality of volume” with any accuracy).
If you are not truly running that 2nd L1 as a ‘remote’ system (one more than 15-20’ away from the primary L1), then you may want to configure the T1 for “stereo” output by using both the Master and Aux outputs. There are notes in the Wiki for doing that
here (with diagrams). This requires using two separate T1 channels, not the single 4/5 channel
(which is really just one channel with two input connections).
As noted above, also, re-confirm that the two L1’s are truly on to same power source.
