Summary
An error message ‘CalcEspResources.exe Internal Error’ is displayed whenever you try to access the DSP resource meter or upload a configuration file.
Cause
This error occurs when the correct version of Microsoft® .NET framework is not installed. ControlSpace Designer up to and including v2.050 requires .NET framework 1.1 to be installed. Versions 2.0 and 3.0 are incompatible.
Product
Designer (v1.001 - v2.050)
Workaround
Install the correct version of Microsoft® .NET framework - Version 1.1
Resolution
Issue resolved - 2.075 or later
From version 2.075 ControlSpace Designer now uses Microsoft® .NET framework - Version 2.0
Links
Microsoft® .NET Framework ver 1.1
