Just wondering if you can link a Sub1 and Sub2 together with Pro32.Or would it be an unbalanced sound.
Hi jdpuente,
Depending on the room/audience size and layout, two Sub1s would likely suffice. You could use a Sub1 and Sub2 together if you wanted to, but I'd recommend turning down the Sub2 to match the Sub1's level for better balance.
As low frequencies are less directional than mid and high frequencies, you may find that one bass module is enough for your setup - of course, again, depending on room/audience size and layout.
Sounds good.Which one links to the Pro32 power stand first,the Sub1 or sub2,or does it matter?
Hi jd,
Up to you! Personally, I'd run to the larger Sub2 first, but it shouldn't make a difference.
