Considering your previous answers to my questions, and that I have not the plenty sure to the mics cables are all wired properly (because all this are into the walls) I have a new question, pretending avoid to use the Phantom Power in my T8S ToneMatch with all my other dynamic Mics connected at same time.
This time I was wondering if the Phantom Power would be required in the T8S yet, if this is provided to the Mic by a Mixer Berhinger SX3242, and the Mixer will be connected to the T8.
That is, if I connect a microphone to the Berhinger (using it Phantom Power supply) and the Mixer output will connected to the T8, The Phantom Power still need activate in the T8 ?
You should only need phantom power from the device that the mic is plugged into. So if you plug your mic into mixer A with phantom power on, then connect to mixer B via mixer A main or auxiliary output, only mixer A needs to have phantom power.
Thank You. So, that means that If the Condenser Microphone receive the Phantom Power from the "Mixer A" that it is plugged into. The "Mixer B" that will receive the signal through the main or auxiliary output from "Mixer A", will receive it signal as a Dynamic Mic?
Actually, mixer A is more likely to receive a signal as a line level source unless there's a switch on mixer B that allows it to output at (the lower) microphone level.
However, almost ALL dynamic microphones have no problem ignoring phantom power so you may not need Mixer A at all.
What are the make and model numbers of the dynamic mics you're using?
Phantom power supplies have current limiting which will prevent damage to a dynamic microphone even if it is shorted or miswired. In general, balanced dynamic microphones can be connected to phantom powered mixer inputs with no problem.
As long as your mic cables are all wired properly (balanced, with the correct pin connections) and well made, and you are using decent XLRs everywhere — and all your microphones are modern — there is no problem at all.
I was worried because I haven’t way to confirm if the wired used are the correctly to prevent any damage in my Dynamics so, that is the reason for my question but, your answers give me confidence to use it.
I consider a simple inexpensive volt/ohm/continuity meter an essential part of my kit. ($20)
You can put it on the ohms' setting and use it as a continuity checker to make sure each pin is wired correctly and that there is not short between the pins...
It's also a good idea to gently jiggle (move) the wire VERY gently where it enters the plugs to make sure the connection/solder joint is secure.
