Can I use the Phantom Power in only one channel in my T8S?
Hi.
Maybe this is a stupid question but, I prefer ask, before cause any damage in my devices.
This is the scenario:
I try to use T8S for recording.
Vocalist use a Shure Mic Super 55 (in Channel 1) but the Mic in Control Room (Channel 2) is a Shure SM27 and this need a Phantom Power.
Can I use the Phantom only for Channel 2?
Or, can I use phantom even if both microphones are connected?
Phantom power on the T8S is switched globally on CH1-4 so no you can't apply it to CH2 only. But if your Super 55 is wired conventionally it will not be affected by phantom power. The term Phantom power was devised to signify that a power source could be applied between both signal conductors and the ground of a balanced mic connection while the signal conductors remain at the same potential (normal 48VDC) so there is no voltage across them. That means dynamic mics and most other modern devices don't 'see' the 'spook power' but those which can use it (DI boxes and capacitor mics) can be powered by it. Very clever system. But you must be using correctly wired balanced cables and there are some devices which are not happy getting 48V up the jack-socket.......
Hi, Miguel Lobo.
Thanks for the great question.
Miguel Lobo posted:
Hi.
When you turn on phantom power on your T8S, it is available for all the XLR inputs on channels 1 through 8.
Yes. You can use phantom even if both microphones are connected.
Will Phantom Power Damage Dynamic Microphones
Phantom power supplies have current limiting which will prevent damage to a dynamic microphone even if it is shorted or miswired. In general, balanced dynamic microphones can be connected to phantom powered mixer inputs with no problem.
Source: What is Phantom Power, Shure.com
As long as your mic cables are all wired properly (balanced, with the correct pin connections) and well made, and you are using decent XLRs everywhere — and all your microphones are modern — there is no problem at all.
Source: Phantom power on Dynamics, Sound on Sound
If you want to learn more, please see Phantom Power
ST posted:
Hi, Miguel Lobo.
Miguel Lobo posted:
Hi.
<dl><dd>Phantom power supplies have current limiting which will prevent damage to a dynamic microphone even if it is shorted or miswired. In general, balanced dynamic microphones can be connected to phantom powered mixer inputs with no problem.</dd></dl><dl><dd><dl><dd>Source: What is Phantom Power, Shure.com</dd></dl></dd></dl><dl><dd>As long as your mic cables are all wired properly (balanced, with the correct pin connections) and well made, and you are using decent XLRs everywhere — and all your microphones are modern — there is no problem at all.</dd></dl><dl><dd><dl><dd>Source: Phantom power on Dynamics, Sound on Sound</dd><dd>If you want to learn more, please see Phantom Power</dd><dd>ST</dd></dl></dd></dl>
Thank You for your prompt, and accurate response. This info will be very helpful to me.
Regards.
Sam Spoons posted:
Thank You Sam.
I'll ensure than my cables and connectors comply with the correct specifications to use this function safely.
Miguel Lobo posted:
Sam Spoons posted:
Thank You Sam.
You are welcome. ST's advice is correct as far as it goes, that a dynamic mic should not be damaged by phantom power, but it is entirely possible that another electronic device, e.g. a keyboard or iPhone would be (say if using the headphone output). And passive ribbon mics, while not usually used for live performance, are very likely to be destroyed by phantom power. It's a bit of a minefield TBF.
Hello again.
On this same scheme, Can I connect Instruments as Guitar or Keyboard in other channels in the T8S while the phantom powered is in use with no problem?
Or this principle only woks with balanced dynamic mics?
Hi Miguel Lobo.
Miguel Lobo posted:
Hello again.
Phantom power is applied only to the XLR inputs. As long as you are using only the 1/4 inch (6.3 mm) connections for the Guitar or Keyboard or other sound sources you will not have any problems.
If your Guitar has an XLR connection - check with the Guitar manufacturer to make sure it's okay to use phantom power.  Some can use phantom power, others cannot.
ST posted:
Hi Miguel Lobo.
Miguel Lobo posted:
Hello again.
Ok.
Only to confirm that I understood...
This means that I can use any input in my T8S from 2 - 8 with a jack cable TS 1/4 for the Guitar and the phantom power activated, will not affectthe guitar or other instrument 'cause it's not a XLR?
Hi, Miguel Lobo.
Miguel Lobo posted:
Ok.
That's right.  Phantom power is not applied to the 1/4 (6.33 mm) jacks in the middle of the combo inputs.
ST posted:
Hi, Miguel Lobo.
Miguel Lobo posted:
Ok.
Thanks so much!
