Can you “save” a grouping of speakers?
I have 2 Bose Home Speaker 500s. Nearly every time i play music, I group the two of them on the Bose app.  Is there a way to save this group so I don’t have to recreate the group every time I play music? It would be helpful to save the grouping, maybe give the group a name and chose that group name when I play music instead of making the same group over and over.
if not, I suggest this as a feature for Bose to consider adding.
Updated:
Hi Thomasleeclarke,
Thank you for posting and welcome to the Community.
Groups made in the app are not permanent and will need to be recreated after turning off the speakers, or they go into standby mode.
It isn't currently possible to save or name your groups in the Bose Music app, but I'll be sure to pass this suggestion along to the development team for consideration. I couldn't say for certain whether this is something that will be added but I'll make sure the team knows this is something you would be interested in!
If you want to keep the speakers grouped when using voice commands, you can do so with Alexa, but not Google Assistant at this time. To create a group for Alexa you would need to follow these steps.
Currently, only Bose Music speakers can be grouped this way, adding other speakers to the Alexa group will not work.
I hope this helps. Let us know if you have any further questions.
Keith L
I ran into the same issue, and here is Bose's tech reply :
"In regards to the speakers not staying grouped, as we have had to comply with new US power saving laws the speakers will go into standby mode after 30 minutes of no usage/playing music. If you're leaving the speakers without using them even if they're grouped for more than 30 minutes they will go into standby to conserve power."
I really wish the grouping would stay after the speaker going into sleep mode, i hope they will include that in a near future feature release !
Hi,
i see that the topic is marked as "resolved" where it is not the case (for me anyways)
I am still sitting with the issue, and as far as i know the statement from Bose's tech is accurate (see above)
I am just wondering if this is something looked into, and if a future firmware release will fix it ?
Hey jbossert,
Thanks for posting! Sorry that you're experiencing some problems with the grouping of your speakers.
When your speakers are going into standby, are you losing the group?
Hi Charlotte
Yes, grouping stops when they go to sleep. meaning i have to re-group them really often, which really makes the grouping unusable / too convoluted to be used
Hi JBossert,
Thank you for coming back to us!
This has been raised to our development team and there is no update at this time. We do not know if this is going to be something that will be implemented in our systems.
I'm sorry I couldn't be of more help to you.
Can you at least make grouping easier in the app, or as a widget in Android?
I would love to either:
a) Have a "re-group last group" in the app home screen
b) Have a "re-group last group" as a widget on my Android screen
c) Be able to save the group as "Group X" and then be able to quick select "enable Group X"
I have my portable speaker grouped with my Home 300 and it is annoying to have to re-group this every day. As a workaround I mute music instead of stopping it, but this is also not ideal.
Hi heartface,
Thank you for the suggestions! It's always great to have suggestions of how you would like to see features implemented, as well as ideas for new features! I'll be sure to pass these ideas along to the development team as well, so they know this is something you would be interested in seeing too.
Hi,
I totally agree on the previous users request : please make the GROUPING function easier, since the grouping can't be saved after the Bose Home 500 goes on standby mode.
This is really disappointing when you invest into 2 Bose Home 500 speakers, which is worth more than 650 euros...
An update about the GROUP function will be so welcome. Thank you. Jeremy
